Bobby Mhor
We'll wait and see.
Not all if the return was with wind at yer back then.
Not often the wind behind you, going downhill had me wondering if your brakes were up to the job. Normally it's against you whatever direction you take.
Bit of meths on a cloth and clean the rotors. Might stop the squeaking.
If you were trying to stop 20 st on a steep downhill, you'd howl as well..
I'll check what's left on the pads and if okay, I'll use Oldwheels suggestion as I have some ...
it also stops bubbles forming when making soap,
spray the mould and then when poured in soap mix, spray and it disperses the bubbles formed
I think one set of pads are near end of life...
anyway..
Toodlepip
