Tea?
classic33
Leg End Member
It worked,
I still prefer the grey one, seems a better finish...
I'll be busy today again..
No wicked for the rest.
The Creality one obviously is a print speed difference but I had to double the wall thickness which slows it down a bit (on the finer items), the key base is okay...but I'll just set it to print at 4 instead of 2, makes life easier in the long run...Weird, once you install an update, its suppose to be better? not the last one..
Better go get the kettle ready, the apple and banana......
It did, and you up at two to check it had finished without sticking.
What colour did you do the one you don't like.
Doing nothing, you got yer stool/chair leg ready...
Any Kit Kat?
Is that the manufacturer of yer printer, or software writers.
I've always wondered about updates and who they're actually intended to work "better" for. End user or the manufacturer. Sometimes they're to fix a "fault" created by the previous update.
You have a workaround, that's the main thing. No thought required about buying a newer model, due to updates not working.
What'd the bumf that accompanied the update say it were for?
Whose the kettle for? I can work out the apple and banana...
