But you've got longer legs than her, and it's your house so you should know all the shortcuts.
When you put it like that, you make it easier understand.
Making the neighbours happy with you if you did it...
Is it just a simple case of switching yer antennae to one that could handle the power output if you were to up the power?
You've me wondering how much power one near me is using with either his "dish" or vertical mast(Which is taller than his house) when he's on the air.
No resitting the exam to make sure your still upto date, or giving you the chance to move up a grade.
So no listening into the gossip about their cooking secrets.
Maybe yer listening at the wrong times.
They left you all by yourself, again. Maybe they don't like your singing.
I could put up anything if I wanted, a beam array and tower could prove troublesome, planning permission etc..
As soon as you put stuff outside, everybody thinks you are interfering with their telly, and all sorts of things..
Last house nobody knew about set-up, a few knew I occasionally put a 5 ele yagi (portable) to work distant VHF but not HF, 66ft dipole started in the apex of the loft and went out and down the back of downpipes and plastic covered wire the same colour of the downpipes (white), it had been up since '81 with a change of wire latterly.
I'm happy what I do..
I'm at the top...no further to go.
Vertical of that size? HF, dish depends on size, bigger ones do moonbounce and stuff like that, others do microwave frequencies, find the callsign and QRZ.com it....you'll find a wee bio most likely...There is a search box, read it carefully
15 mins on and no contacts
Usually grab an early bird or two..
Oh well, Toodles Jnr about to appear..
2 mm of rain so far and lowest temp 2.9 or something
The oats and coffee call.
