technical knowledge
mikeruss
Teesside
hi, i need to set up the front and rear derailures on my giant defy 5, the chain is slipping when i am moving into higher gears on the small ring at the front, i adjusted the tensioner on the rear derailier until it seems ok, then when i moved into the big ring on the front it was doing the same again on the rear. i have removed the crank arm to clean the bottom bracket will this be the problem? i do want solve the pronlem myself so i am not going to pay a shop every time something needs fixing, or am i better off taking to a shop
subaqua
What’s the point
Leytonstone
View: http://www.youtube.com/watch?v=2j1gSwhsVN8
Should help . Shimano and SRAM have good tech pages too
What I would do. Firstly don't touch the limit screws (If it's not jumping off the cassette) they should not have moved so should be OK. Turn the bike upside down. Shift into a middle cog.
Look from the back and align the derailier so it is in line with the said cog using the barrel adjuster. Shift up to the top readjust if needed. Shift down readjust if needed. The cage actually is usually just slightly lower than the cog I find. Repeat until happy.
If if won't shift into the top or bottom, then adjust the limit screws.
  • Like
Reactions: gbb
gbb
Peterborough
Its so often you'll see people suggest adjusting the limit screws, like the first thing you should do. Its not ...and Leaway is spot on saying so.
In circa 40 years of cycling, the ONLY time I ever had to adjust limit screws was when fitting new derailleurs.
compo
Harlow
I have just had to adjust my limit screws without replacing the derailleur.
I fitted a 5 speed freewheel in place of a knackered 6 speed one. Come the New Year I will get a new 6 speed then have to readjust the limit screws again.
But yes, I agree about not touching the screws unless really necessary.
  • Like
Reactions: gbb
gbb
Peterborough
I'll let you off with that one :thumbsup:
