BenScoobert
- Halifax
I recently got the croix de fer and it no longer comes with the tekra top mount brakes. I decided they were ideal for traffic situations and ordered them.
In the shop I asked how they gripped the cable and either I'm stupid or he is bad at explaining things.
He said you cut the cable and it is gripped by the lever.
I said if you cut the cable you have 2 frayed ends.
He said you pull the cable out 1st.
I said ah so you cut the outer sleeve and it grips the cable in the gap you make
He said yes
Looking at the levers theres nothing which grips anything, just a hole for the cable to pass through and a wider bit around it for the plastic, I still fail to see how that pulls the cable inside the sleeve outer. Common sense says it pulls it all.
Can anyone explain it to me?
He said yes
