I don't ask much of my daughters for Christmas... I gave them the grid reference!
The secret with ours is to get plenty of wood on and then leave it alone with the top vent shut (closed to 80% by the DEFRA modification kit) it then just glows for a good 4 hrs before you either let it go out or reload it.![]()
NOIf you have any spare, can you deliver it to Wales ?![]()
NO as there is no such thing as to much wood just to little storage space.If you have any spare, can you deliver it to Wales ?![]()
I was told by a heating engineer that it is more efficient to keep it on all the time but when you are out, turn the thermostat down by 3 degrees so that the boiler doesn't come on full again when you bring it up to normal temperature. It is all to do with keeping the walls warm apparently.
Eh? That sounds like a load of crap to me. Imagine your house is like a kettle. Is it more efficient to heat up the water in the kettle when you need it from cold or keep the water in the kettle warm all day?
Of course it is more efficient to heat up the water when you need it from cold. There is confusion between "Which method requires the least energy" and "Which method allows the house to heat up most quickly".
Your analogy is weak as you can't compare it to a kettle. The walls of a house take a while to warm up, a kettle doesn't. It makes sense to me to keep the walls warm as a lot of cold comes through the walls, that's why a house in the middle of a row of terrace houses is warmer than the ones at either end.
Minimum energy usage = turn the heating off completely when you don't need the house to be warm, let the house cool down, then blast the heat when you need it
You lucky spud. I really miss my wood burner. We are not allowed to fit one as it messes up the eco rating of the flat apparently.A man and his fire is a wonderful thing. I don't have central heating. I have a wood burning stove that heats the whole house. When i had central heating, we left it on on low all day rather than turning it on and off. We had thick stone walls and the heat was absorbed into the walls during the day, and radiated back into the rooms during the night. The walls acted like a radiator.
