The touch-up-paint-sources thread
wafter
Oxford
One for the more gear-proud / obsessive to share anything to do with sourcing appropriate paint as this can be a bit of a pig.
Many manufacturers make paint codes available for current / recent models; either in the documentation with the bike itself, on its box on on summary documents on their websites.
For example Genesis make available a list of their codes in the FAQ section of their site; although unfortunately it doesn't look like it's been updated since 2021 :sad:
Similarly Ragley also publish a list of recent ones on their site - probably worth downloading it while you can if you have one of their bikes, since the company is no more and the site will likely die eventually.
Paint codes refer to a specification defined by those within the industry - sometimes non-profit standards organisations like RAL, or companies such as Pantone. There are many different purveyors of standards, while each might offer a number of different specifications - RAL for example offing "Classic", "Effect" and "Design+".
I've had good luck with Condor Cycles who supply acetone-based touch up pots in quite a few colours off-the-shelf (including those for Bromptons) as well as mixing me a couple to RAL effect specification (which I'd had trouble sourcing elsewhere).
While probably not perfect they're pretty good, and given production variations plus the inevitable changes in applied paint that's subject to environmental factors it's probably unrealistic to expect a perfect match; however "close" is better than a gaping rusty hole :tongue:
While Condor were very good at supplying the RAL stuff they couldn't help with a couple of others I was after - one a TC-prefix code (apparently a Pantone standard), the other with a YS prefix (apparently an "Asian" standard).
I've just found GPaint which looks like it might be a good bet as they're coming at it from a bicycle-centric angle and some of the prefixes are familiar; if their wares are a bit spendy.
Anyway, I hope that this thread might work as a resource to help us qualify, understand and source paint for our rides :smile:
Punkawallah
Apparently old steel frames paintwork can be repaired with Humbrol enamel. My ‘go to’ for finding quick repair solution is to ask the nice lady at Boots nail varnish counter for a matching colour to my frame.
All uphill
Still rolling along
Somerset
That's my approach, too, but I prefer Superdrug. They don't mind me taking my bike in the shop, at a quiet time.
Seriously
