The true size of each country.....
Discussion in 'CycleChat Cafe' started by jay clock, 7 Dec 2017.
  1. jay clock
    jay clock Massive member
    Hampshire UK
  2. Spinney
    Spinney Bimbleur extraordinaire
    Under the Edge
    Hmm. But it uses Mercator Projection (or something similar) which makes the sizes of countries near the poles look far too large, so it is only really good for comparing countries at similar latitudes.
    Great idea, just wrong map projection!
    e.g compare the map on that site with a Peters Projection map - easiest comparison is to look at the size of Greenland on both maps.
    Edit: I take it all back - I didn't play enough!! Excellent site, shrinks Greenland as you move it south!
    Drago, Fnaar, uphillstruggler and 2 others like this.
  3. Rickshaw Phil
    Rickshaw Phil Overconfidentii Vulgaris Moderator
    If you select the country of your choice and drag it round the map it changes the size to show how the mercator projection distorts things. Interesting site.:okay:
    User1252 and mjr like this.
  4. Spinney
    Under the Edge
    Ooh, missed that!
    *goes off to play*
    **erroneous complaining post edited** :blush:
  5. User482
    User482 Guest
    Alternatively...
    queasyrider, BSOh and ianrauk like this.
  6. twentysix by twentyfive
    twentysix by twentyfive Clinging on tightly
    Over the Hill
    In that world doesn't the sea drain away? :unsure:
    classic33 and burntoutbanger like this.
  7. Bazzer
    Bazzer Setting the controls for the heart of the sun.
    Fnaar likes this.
  8. queasyrider
    queasyrider Still perplexed
    I thought that countries, drought areas, deserts etc. were all measured in terms of Wales.
    Fnaar likes this.
  9. YukonBoy
    YukonBoy Veteran
    Mars
    Nope measured in terms of hamsters
  10. queasyrider
    Same difference...
  11. FishFright
    FishFright More wheels than sense
    The same as when it's the other way up .. ie Many, many pipes and pumps. Also plumbers, lots and lots of plumbers. Why else are they always busy when anyone needs one?
  12. queasyrider
    The world is clearly flat from those diagrams. There's a dam all around the edges to stop the water running away.
  13. slowmotion
    slowmotion Quite dreadful
    lost somewhere
    Ah yes, the penguins' atlas.
    classic33 likes this.
  14. Fnaar
    Fnaar Smutmaster General
    Thumberland
    Or the equivalent in Belgiums
  15. Drago
    Drago Guru
    Central Trumpland
    That projection is all wrong. The UK should take up most of the North Atlantic.
    Dismiss Notice
