Thru axle position
DWM
Hi All
I have thru axles on my Genesis Equilibrium Disc. When the front one is tightened the correct amount, the lever on the true axle points forwards. As well as not being aesthetically pleasing I guess there is a risk it could catch on something. Is there a way of adjusting this? Looking at pictures online, some thru axles appears to allow some adjustment of the final lever position, but I cannot see anyway of doing it with mine.
I plan to look at it again tonight and will try and take some pictures.
Cheers
Dave
StuAff
Silencing his legs regularly
Portsmouth
Hi All
Cheers
Dave
Seems unlikely that you couldn't adjust it, most do. DT Swiss RWS axles on my Litespeed, they have plenty of scope for adjusting the lever position. Does the lever not push in once you've got the axle tight? When you push it in, you should be able to do so from any angle.
Loch side.
Hi All
Cheers
Dave
Show us a photo of the threaded side of the fork and the lever side of the axle.
Further, don't worry about any through axle or QR lever that points forward. The "theory" that it could hook on something and cause the wheel to come off and make you fall is silly. Anything that close to your wheel will make you fall. It'll catch on your handlebars or crank in anyway. The type of force required to open those things is greater than the force required to push you off your bike. If it points forwards or backwards and hits an obstacle, you are coming off. Period.
DWM
Thanks both for your comments.
I will take some photos tonight.
I don't disagree with this. It still looks awful though!
Cheers
Dave
SpokeyDokey
Into my 64th
I thought my Specialized was the same until I realised I could pull the lever out and twist it to what position I want and release. It feels like it is on a spring.
I thought they were all adjustable once they had been tightened up correctly.
The ones on my Trek are like yours - do them up tight enough and then pull and spin the lever until it points in your favourite direction and then release.
Loch side.
There are some pretty primitive ones out there. The only solution in that case is to try a few different axles. Since the start thread and lever position is random, you may be lucky to find one that stops where you want it to stop.
DWM
It turns out it can be adjusted, although it seems a little crude.
The axle has to be removed, and then the position of the threaded part can be moved.
It involved a bit of trail and error, but I got it in the right place eventually.
Cheers
Dave
It's about right. The Rockshox through axels do allow the lever to be moved. The only thing is, they are made of cheese, so you have to be careful.
DWM
That's rather elegant, actually.
Maybe crude wasn't the best word to use. It seems less sophisticated/more fiddly than the axles that can be adjusted in-situ, but certainly does the job.
Cheers
Dave
