nickAKA
- Manchester
Morning folks,
My Btwin bike has a typical 10 speed Tiagra 4700 groupset with compact crank. I'm thinking of putting an alternative cassette on a spare rear wheel for the very hilly stuff; The current setup is an 11-28 cassette, I've got an 11-32 cassette which I'm hoping I can use... the bloke in the LBS reckons this won't work (he thinks max I'd get away with on a compact crank is a 30 which aren't that easy to come by plus buying another cassette - http://www.wiggle.co.uk/miche-primato-10-speed-cassette-shimano-1/).
Bearing in mind "bloke in LBS" has been wrong about (lots of) things I've asked him, is there a hard & fast rule on compatibility of cassettes / groupsets?
TIA
EDIT - crank a red herring? Rear mech / chain length the issue?
ANOTHER EDIT - does this suggest compatible? http://productinfo.shimano.com/#/com/2.0?cid=C-544&acid=C-256
TIA
