Tighten up the back brakes on a Brompton M3R
Kell
There are normally two things you can do.
Tighten the barrel adjuster on the brake lever or by slackening the bolt in picture one and pulling more cable through, then retightening. The first one is easier for small adjustments and because you sometimes need three hands to do the other one.
shouldbeinbed
Rollin' along
Manchester way
This ^
& +1 try the barrel adjustor first before fiddling with undoing the cable itself.
It looks like there is still plenty of rubber on the block but I'd just check that they're both still in good nick and worn evenly too.
