TLR tyres are so tight ....help please
Dogtrousers
Lefty tighty. Get it righty.
If the problem is pushing the bead off the rim initially, tyre levers don’t help as you can’t get them under the bead. I struggle myself with this on tubeless tyres, two options stand on the tyre and pull up on the spokes which rarely works for me or get a piece of wood but it against the edge of the rim and give it a whack. That always works.
I've got a tyre lever with a very pointy end ( came with some tubeless stuff I bought) that is specifically for getting a well seated tubeless tyre off the rim.
Would a pair of mole grips do it. Expand, put over tyre, pinch together.
geocycle
Levers are the answer but don’t over do it. I asked mine to do too much lifting and dented the rim! You still have to do everything possible to get it into the well.
Ming the Merciless
There is no mercy
Photo Winner
Inside my skull
Both thumbs pressing on the tyre just above the rim to release the locked in tyre beads. Work your way round. Too late now, but if you intend to use tubes buy the version of the tyre designed for them.
gbs
gbs
Fulham
Set them up tubeless then you can use tyre levers with no tube to pinch. Failing that keep working round, even with my week fingers Ive never had a tyre which after a few rotations failed to go over the rim.
Working round doesn't immediately appeal BUT I think it must be tried. Thanks forthe suggestion.
gbs
gbs
Fulham
I've been successful with some tight fitting tyres ...
Using three slender alloys tyre levers.
Working opposite to the valve, insert the first tyre lever, but not yet attempting to lever off.
Then insert the second tyre lever, no more than 1.5 ins apart, then insert the third, again, no more than 1.5 ins apart.
Then using hand and forearm, lever all three levers at the same time and hopefully the tyre comes off.
May work for you
Good luck
Do you recall the brand? The Leyzne version costs £14
gbs
gbs
Fulham
I will try with new levers but if that doesn't work I will revert to the tubeless solution. I understand the fluids self-seal more readily nowadays. Given the cost of tyres I am reluctant to immediately discard the current TLR tyres and replace with "tubes only" alternatives.
i regret that my initial post did not clarify that I am riding with inner tubes
YMFB
I bought one of the tyre glider, sliding type levers, I think it’s great especially at putting tyres on.
PaulSB
I've found this tyre lever from Crank Brothers works very well
Speedier Tire Lever | Crankbrothers UK https://share.google/dDPkFFQAR58kiCZG1
There's also a thing called the Tyre Glider that works in a similar fashion. It might help but I doubt it. The Glider is a product many got very excited about a couple of years ago. Mine now lives at the back of a dark drawer. Useless.
geocycle
Same here, I’ve never found a tyre/rim combo that suits the glider. I don’t see how you can avoid standard levers for initial removal to enable you to run the glider around.
Dogtrousers
Have you a link to that please or a photo?
here it is.
Looking at it closely, the pointy bit that I thought was for disengaging the bead from the rim is actually marked as being for mounting the tyre. I am an eejit.
