Touring on a MTB frame
iLB
Hello there
LONDON
Have you done it? How does it work compared to a road bike geometry ? Is it a good idea?
GrumpyGregry
Here for rides.
Done it? Yeah loads back in the days when my rockhopper was the only bike I owned or could afford. Slower going than on a road bike and slick tyres are a must, imo, unless you're going off-road, Loads of folk do it, loads of Amer I Cans wouldn't tour any other way. Heel clearance sometimes a problem with shorter chainstays and large panniers and watch the handling if you move them backwards to suit.
iLB
iLB
Hello there
LONDON
Interesting, I'm going to Romania for a year starting next month- want to ride over there at some point. Trying to decide between flying and riding the on the first trip...
Alan Whicker
I toured the Lake District about 12 years ago on a Claude Butler (AKA Radford) Xanthos rigid steel MTB. It was very comfy indeed, with relaxed geometry. My mate was with me on a Saracen Rufftrax. It would have been a bit easier rolling without knobbly tyres, but we thought we'd go off road at some point (we didn't in the end).
Nigeyy
I've toured on a couple of mtbs with no ill effect. However, these were older early-mid 1990's bikes with no rear or front suspension, so they had more of a traditional road bike geometry with longer chainstays (as opposed to the newer mtbs now which have geometries that take into account front shocks). I'd certainly not hesitate touring on an old style mtb -no problem. I would not recommend front suspension as it sucks up energy, and certainly much less a full suspension (let alone the problems associated with affixing racks). I currently use my backup tourer (90's Specialized Hotrock) as a commuter bike complete with racks.
So to summarize: yes, it's a good idea if it's an older style mtb with no suspension and a more relaxed geometry, you don't have to spend too much money to get it to where you need it to be, and you don't want to spend the money on a purpose tourer.
Advantages:
-cheap (really cheap to get an old mtb if you keep your eyes open)
-usually an easy way into touring; change the tires and tubes, slap on a rack, and you can be good to go!
-gearing is ready for touring. Mtb gearing is much lower than traditional road gearing, and for touring carrying a big load, that's good!
-some of the brakes on the mtbs were first class (good cantis or v's)
-assuming you use the flatbar or butterflies, no need to change shifters
-assuming you get a good example, the drivechain is inexpensive to replace parts.
-usually tough -remember, these were supposed to be mtbs
Disadvantages:
-not a "proper" touring bike
-may not have touring specific stuff on the frame like spare spoke holders
-if you want to use drops, then the cost of changing over can be expensive (E.g. new bars, new brake levers with possibly new brakes, new shifters, probably a new stem and new front derailleur if you wish to use STI)
-doesn't have higher gearing
-can be heavier
-may need a heavier duty wheelset if you need 36h as most mtbs come with 32h wheelsets.
-may end up spending as much as a proper tourer in an attempt to get it to where you want it to be (don't ask)
bigtim
Yes Devon rail trails on a 1990 Kona Lava Dome, 28mm Conti Gatorskins, on skinny Shimano factory wheels with not many spokes and nipples at the hub, very fast as light wheels are what makes any bike climb, accerate or hold top speed. For comfort ergo grips with build in ends are a must to give the hands alternative positions to rest.
1993 Marin rigid. Used it for a few small tours recently and it handles it really well. Stays are just long enough to avoid heel strike and it's stable and comfy. It will eventually become a tourer when I finally get a new mtn bike.
Sara_H
Depends on what kind of touring you want to do - I prefer to use the off road paths as much as possible and alot of these can be quite rough in places, so a mountain bike is ideal.
I use a Myka Elite, which I've adapted with a rack and some wide slick marathon tyres. It's slow going, I aim only for 30 - 40 miles a day, but thats the kind of touring that suits me!
As Sara_H says it depends what sort of touring you do, I started off touring many years ago using a purpose make touring bike, then I found that when MTB kicked off I converted to using MTB's. Having toured over many miles, in Europe, Africa and Asia using MTB's I feel that for me the MTB is the Bike of choice, currently using one I made up to my own spec which is as follows.
I made my Mountain bike up to so suit my own requirements for pottering around on the trails and byways and also for longhaul touring doing 40-60 Miles per day:
Charge Duster 2010 frame, (has bigger diamenter tubes than the Duster 2011 frame)
RockShox Recon Silver TK Solo Air 100mm Suspension Fork
Hope Tech X2 Disc Brake front and rear.
Truvativ Noir XC 3.3 Team Triple Chainset.( got it for £90 so could not miss such a good bargain)
Shimano XT M770 Derailleur and levers front and rear..
Race Face Evolve MTB Handlebar
Charge Spoon saddle (result of trying different ones over a few years touring)
Mavic Crossride XC717 front wheeL
Halo SAS Pro 26 Inch Rear Mtb Wheel (heavy wheel but great for when I am touring off road fully laden)
Old man mountain Sherpa racks on the front and rear. (taken off for day to day use)
Current tyres are Schwalbe Marathon XR's for touring otherwise when not set up for touring: I use Panaracer Fire XC Pro's
BalkanExpress
Brussels
It's a much better idea than, for example, doing a FNRttC on a BMX^_^
As others have said yes very doable. One thing you would want to look at is hand positions. I would not want to do 1000+ km on just flat bars, bar ends give some variety and others will no doubt have views.
fimm
Edinburgh
A friend of mine did an extended tour in south east Asia on a modified mountain bike which seemed to work very well for her.
Yellow7
Milton Keynes
My first three tours were on a Raleigh steel frame MTB & my present touring bike frame was designed around that as far as sizing, no suspensiopn on either as more to go wrong, just use a sprung Brooks saddle, I also use euro / touring bars for change in positions. 26" wheels have there advantage in African & Asian countries as standard so easier to get tyres if needed.
Crankarm
Nr Cambridge
I have and am doing it! :blush: Kona Kula hard tail with front suspension locked out most of the time. I am currently riding 60 miles a day to and from work with panniers - rear but can fit fronts if needed. I ride paths, pavements, cycle tracks and the GBW. Frame is super stiff, strong and lite. Tyres are Marathon XRs 1.6 inch. I do have 2 inch wide versions but these are for hard core off road expedition. I was thinking of fitting a solid fork - Surly Troll, but tbh having the facility of a front shock for shocking surfaces is worth having, so haven't. No probs with heal clearance with rear panniers Vaude Aquas. Rack is an uber strong Madison Summit. I have a suspension seat post as well which makes all the difference as does an Airzound. A spoke broke in the wheel of normal commuting bike and my Brompton is off the road. So the MTB it is. HTH.
Done it, but much prefer my touring bike (Scott Scale 40 verses Thorn Nomad Mk II). Hands were an issue with my left hand going numb but I have a known left wrist issue anyway. travelled with rear panniers and rackpack (dedicated bag across rear panniers than clips onto them) and barbag only. We fitted ergon grips and bar ends to aid comfort. The main problem I came across was wearing everything out so very quickly (we did quite a bit off road - every moving part needed replacing when we returned, but my MTB was never meant to take even a pannier rack so this was not really surprising) and the very many punctures we had, so changing to dedicated touring tyres is a must (my tourer has had 1 visit from a certain fairy in 14,000km, verses my MTB on tour which had 6 I think it was in 1,000km on mtb tyres).
