What about if you flash your lights at the sensor? I once saw a sainsburys delivery van do that in the morning he flashed his lights.
Nope - don't work. Don't care how many people believe it does- it don't. 20 years of installing and maintaining the things is a bit more experiance than most and the sensors on the TL pole do NOT detect flashing lights [still, believe what you will].
The pole mounted detectors usually sense an object approaching at a speed of about 5 - 10 mph so don't creep up to them and they are angled not to detect things in the gutter/ on the footpath.
If inset type in the road [look for the tell tale black shape cut into the road surface] be carefull that the last on [at the stopline] is not a square. If it is try to stop on the line of the cut [on top of the cables] not in the centre of the "box" where your tiny mass of metal may be too far away from the cable to be detected.
Also be aware that many sets in the rush hour are under control from the traffic control offices [every city has them] and designed to speed the flow of traffic into [or out of] the centre. and may well not "service" a side road for several cycles. Also in a large junction if the main roads are running to "max" ie maximum time allowed by the time a small side road gets a green the time can SEEM to be forever [just try sitting still waiting for five minutes - it can feel like hours].
Finally not all TL engineers are "stupid" or "dumb" and many of us ride bikes too and take care to make sure the lights DO detect bikes. I'm sorry but 90% of the time the problem is impatience. "Oh I waited X minutes and nothing happened then a car came along and they changed" - the clue is in the "I waited X minutes".
Finally there are only three possibles
1 - there is a fault on your approach detection. This would cause a PD [permanent demand] and the lights would always assume there is something there [a fail safe]
2 - there is no fault and you are impatient [sorry but often true].
3 - the detection has not been set up/maintained correctly and needs to be reported to the council
If all else fails I would just hop off and walk the bike across. For the sake of a few seconds is it really worth taking a risk ? After all we need more cyclists - not more accidents.
