Travoy Inspired Trailer Project
KuroSan
Regular
London UK
One of my numerous "coming back to haunt me after 30 years" injuries I have, is post-traumatic arthritis of my right hip. While my other creaks and groans all make riding more difficult, this one is the worst as it affects how far I can actually walk, but is fine when I ride, which is part of the reason why I started riding again as it's actually way less painful riding 5 miles than it is walking 1 mile, especially when i go shopping. Currently i'm dragging one of those old dear 2 wheel trollies 1 1/2 miles to the supermarket and then back home with around 30lb of stuff, this takes me out of action for at least the next day!
So I started looking at bike trailers and quickly discovered that none of them would work for me when it comes to getting everything back into my flat, the closest I found was a Burley Travoy, but they're a little out of my budget, even 2nd hand and most importantly, it's still too wide to fit through the doors of the stupidly small lift in my block, which will be a problem when it comes to being fully loaded. I even looked at sack barrows, but those were too tall, too heavy and had bespoke fittings that I would struggle to replace if they broke.
This led me into building my own version of a Travoy, minus all the folding parts and narrow enough for the lift. I also needed to be able to hook it onto a supermarket shopping cart so I can pack everything straight into the bag when I checkout, I've been able to use the original trolley bag as it's quite strong, waterproof and will mount via the 2 upright tubes the same as it does on the old trolley. While looking for tubing to use, i found a place online that sells tubing and fittings for handrails etc with everything cut to size and used their parts list to knock up a basic mockup in Blender, using the dimensions of the original trolley as I know that currently fits where I need it to.
The design is based on using 27mm tubing and 10" wheels, I did originally have the axle tube as adjustable so I could put bigger wheels on it if I needed to, but at the moment I'm just having the axle running through the bottom corner tube as having the wheels too far up the main upright tubes means the trailer will be too upright while being towed, which isn't ideal.
I'm going with a mini-towball type of hitch although i'm not 100% convinced it'll be any good, but I'll know for sure once I start testing the trailer. I have had to fit a rear rack to the bike as a way of keeping any towing arm as short as possible, the alternative being a stupidly long arm over the rear wheel to the hitch attached to the seat tube which will cause collisions with the wheel itself, again, not ideal.
I bought the tubing and fittings a few weeks ago, I did originally make the mistake of being too overeager with tubing strength and ordered galvanised steel, which was tough as hell when put together, but just weighed far too much, so I reordered the tubing in Aluminium and now it's a more realistic weight.
I've got it all built as a test fitting and am currently going around and marking all the grub screw points on the tubes, so I can drill them in order to partially screw the grubscrews into the tubes for a more secure fit rather than just pressing against them.
Here's where it is so far!
I still need to figure out how I'm going to mount the wheels, the ones I bought do come with individual axles, but to use those I'll need to drill through those and the axle tubes and that's a little more precision drilling than I'm equipped to do, the other option is i buy a length of 20mm bar, thread each end and use some washers to compress fit the 2 wheel bearing races to the axle tube.
As it stands right now, with the price of the Alu tubing, fittings, wheels and towball gubbins with VAT & shipping, I'm into it by about £120. I'm not counting the cost of the original galv tubing as I have another plan for that anyway.
I'll take more pics once I have everything drilled and assembled properly, including the slightly dubious looking solution I came up with for the hitch! :biggrin:
ianrauk
Tattooed Beat Messiah
Rides Ti2
Great project. Look forward to seeing the finished trolley.
Anthony-C
For anyone following this thread with intent, our local tip has a forest of unwanted walk-frames and such and the one I liberated is 27mm aluminium.
KuroSan
KuroSan
Regular
London UK
I think I'd epoxy the tubes in too.
Axles are always an issue tbh. Bearings might be the way forward.
I'd rather avoid epoxy as I may need to adapt or change parts over time, although that is something I've considered as a last resort. The 12mm grub screws into the tubes should be ok with some threadlock, I could also possibly epoxy the screws in place too, but again I'd rather wait and see how the trailer works before I take more permanent measures like that.
The wheels have sealed bearing races already so the bar I use for the axle doesn't need to move, it just needs to fit inside the frame tubing, the issue I have there right now is the frame tubing has an inner dia of 21.7mm and the wheels have an axle width of 12mm. The stub axles that come with the wheels taper upto 20mm, but would require me having to drill through that and the tube straight enough to use a retaining pin/bolt, which is why I'm now leaning more towards just using a straight through axle and some sort of shim to keep it central in the tube.
I looked into that as well at first, but the tubing on the ones I looked at were thinner walled and I wanted something that I could be sure wouldn't bend once it's fully loaded and hits a bump or something, I also have the limitation of not having much in the way of metal working tools, so when i found the metal supplier offered free cutting I just went with that!
There's also an element of me liking to make things as modular and replaceable as possible with an aim to making it so that anyone can order the parts and build their own with minimal engineering knowledge or specialist tools, it's not a completely low budget build, but it is cheaper than the alternatives and feeds my need to constantly tinker with stuff! :biggrin:
