3tyretrackterry
- East Midlands UK
Hello
I have a trice Explorer and the front LH wheel is rubbing slightly. I think it is coming from the hub so took hub apart and greased axle cleaned braking surfaces and put back together again. This has made it better but still not as good as the other side which i havent touched. It just seems to slow down faster than other side when you spin the wheel I did find that if i did the axle nut up to tight then the rubbing increased but also if i loosen it off to stop the rubbing completely then it is too loose. Can anyone help me and or point me towards what i am sure is the totally obvious solution that i cannot see
Many Thanks
Ian
Many Thanks
Ian
