to CC Rick.Thanks mate, yes I keep my tyres at 90 psi because I know about tyre pressure because I have been an mtb' er for years and have just started my road biking lifeto CC Rick.
Tip of the day - the best puncture protection you can get IMO is...................................................the correct tyre pressure.
If you don't have a track pump then invest in one, the Topeak JOE BLOW range are very highly regarded, FWIW I use their Max II pump. Check your pressures regularly, top them up and keep them up.
If you really want to upgrade what are the roads like around your way? Some tyres offer superb grip but wear quickly, others are regarded a tad more skittish but wear extremely well and offer great built in puncture protection.
Unless you have money burning a hole though I'd second what Ian said, wear out your original tyres and then upgrade, in the meantime you'll have loads of time to baffle your brains with tyre choices.
what does 700x25 mean? . The bike I have is the new white triban not the old red model.I had also had a triban 3 and the best thing I did was to ditch the tyres that came on them. they had no grip and I didn't feel confident on them, then after 300 miles the sidewalls started to fail.
What do you want from the tyre? grip? speed? puncture protection?
I wanted grip and puncture protection so I went with Schwalbe Durano Pluses. But watch your clearances around the brake callipers. The T3 had very minimal clearances and this did cause tyre size choice issues. Mine was absolutely max of 700x25c and better on 700x23c.
That's the tyre size. 25mm width to fit a 700C type wheel (622mm diameter). The size you currently have will be marked on the sidewall of the tyre.Wha
It's the tyre width. My road bike runs on 700 x 23 tyres but will take 700 x 25 if I wanted, (although not with guards).Wha
I've had the complete bike since Christmas but didn't get out on it till February due to bad weather. So all in all the tyres haven't done many miles at allHow long have you had the tyres Rick ? If they are worn out (p'turing more than normal is a good sign) you need to consider properties such as grip (especially in the wet), roll, p'ture protection, durability and cost. For excellent grip and roll properties and OK p'ture resistance, I like Continental Gran Prix 4000s. For all round however, I prefer the Mitchelin Pro 4 Endurance.
Thanks philThat's the tyre size. 25mm width to fit a 700C type wheel (622mm diameter). The size you currently have will be marked on the sidewall of the tyre.
