Unable to tighten cassette to lock cogs fully - Solved, cheers all
Mushroomgodmat
Norwich
Bit of an odd one this I think.
I have a new set of wheels (falcrum racing 5), and a new cassette. No matter how hard I try im unable to tighten it enough - the individual cogs have slight movement on them, and I can see a gap between them of about 1/3 a mm. Its a very slight gap, but a gap all the same. You can hear them clatter/rattle together if I bounce the wheel.
I tried to fix this a number of times - took the cassette off, reset it, re tightened it, but no matter what I was unable to close the gap between the cogs and they continued to rattle.
So in my annoyance I took the rear wheel off my 2nd bike which also has exactly the same wheel set (not new, but about 9 months old, but exactly the same spec/model) and fitted the new cassette to that - doing exactly what I had done on my new set of wheels
And low and behold it fitted just fine - No rattle, just right.
So I swapped it again back to my new wheel, and its loose. Put it back on my old wheel and its fits fine again.
This tells me there seems to be a slight tolerance issue with my new wheels. But does anyone have any other thoughts/or experienced something like this before/any fix anyone knows of?
cheers all!
Btw - fitted with a decent torque wrench set to 40nm. I probably tightened it a touch past that too.
Tim Hall
Crawley
My guess is there's a spacer that you can't see on the freehub of the old wheel.
M
Mushroomgodmat
Norwich
Going to check.
Is one wheelset 10 speed and the other 11 speed?what is the cassette?
Hope not! lol, both cassettes are Shimano 105 5700 10 Speed - 11-25. And the wheels are simply Shimano 10/11 speed hub.
Some wheels need a spacer that goes on before the cassette, depends on the hub/cassette combination.
Im pretty sure thats in place. But going to double check
Stick another spacer on or use a thicker one.
Interesting....thats more than doable. I suspect that would be okay. Ill double check the above comments, but if those done work Ill order a spacer/shim to fill the gap. As I said its very small.
Some freehubs need a spacer as they are slightly wider than Shimano as 10/11 non-shimano freehubs take 10/11 cassettes, but with Shimano you get upto 10 and completely different 11 cassettes.
PS Put the spacer on first - next to the spokes.
M
Mushroomgodmat
Norwich
Yep! cheers for you help all, think ive done it
In the guff that came with the wheels there was an additional spacer that I missed - fractionally fatter than the one Shimano supplied.....Popped it in and all the cogs are nice and tight and spinning as expected :smile:
Slightly odd that my older wheels don't need to use this spacer, Im guessing Falcrum made a slight design changes to the hub... But either way - the cassette fits as Is should!
