it is a chemical reaction that requires moisture. air tight also seals out moisture .I would of thought cement needs air to fully set though , stick some in an air tight tub and it takes ages.
it can be poured and submerged almost immediately. and yes the water does help with the curing as it helps remove the heat generated by the curing process.
Lime Mortar however is not able to set under water
Have you got his email address? We could ask him how long he left the brickwork before sluicing it down with sewage.BTW, did you know that the sewers are egg-shaped in cross section so that when there is little flow, the stuff runs faster and helps prevent blockages?Joseph Bazalgette specified Portland Cement for his work on the London Sewers in he 1850's, & the vast majority are still used (he designed with very excess capacity!)
Yes, ovoid, with the narrower section to the lower point, so, yes, it was self-scouringHave you got his email address? We could ask him how long he left the brickwork before sluicing it down with sewage.BTW, did you know that the sewers are egg-shaped in cross section so that when there is little flow, the stuff runs faster and helps prevent blockages?
Did they use sand in the mix or granite dust ?
