Gerry Attrick
I sometimes wonder why I bother answering technical queries. Like I said earlier, Catrike is absolutely correct. He has thirty years of experience, I have forty years in. I have been involved with cycles, motorcycles and industrial (marine engine) chain drives all this time. Where an exposed chain is operating under load, this uneven wear pattern is manifested. Period. You amateurs can pontificate all you like about eccentric chainrings, but modern chainsets are manufactured to very tight tolerances and it is highly unlikely to be the cause of the symptoms described by the OP.
Changing the chain has solved the OP's problem, and yes the problem may or may not recur in the future, but replacing brake blocks is only a "temporary" repair for ineffective brakes.
"There is none so deaf as those who won't hear" is a true adage. Those who are clearly stone deaf see fit to tell the orchestra it is out of tune!
In my previous post I asked Zoiders for the basis of his assertion. He failed to respond to that question. Catrike and I have proffered our credentials. Now is his oportunity.
