Don't worry if all the forums and threads have suddenly appeared as unread. I have changed the way that read/unread markers are applied to threads.
The previous cookie-based system was a bit hit-and-miss and would often shown threads as unread when you've actually read them. I've changed the settings to use a database system that should be more accurate.
Unfortunately, when you make the change every forum and thread is shown as unread to every user. Once you start viewing threads the settings will 'stick' and be retained. After 10 days, any threads you haven't read will be automatically marked as read.
Sorry to throw this at you without warning, but I only just found out about it and wanted to get it going straight away!
Cheers,
Shaun
(The pesky admin bloke!)![Wink ;) ;)](/styles/default/xenforo/smls/wink.gif)
Cheers,
Shaun
