USB 3.0 hubs
Shut Up Legs
Down Under Member
Hi all,
I'm trying to find USB 3.0 hubs with the following characteristics:
  • At least 4 USB 3.0 ports;
  • At least 7 ports total (i.e. a mix of USB 3.0 and USB 2.0, or all USB 3.0);
  • Amperage on the power supply to be at least 4A. This is because I want to be sure that it can power as many devices as possible. USB 2.0 devices need 0.5A each, while USB 3.0 devices need 0.9A each. Of course, I understand that different devices will draw different currents, and that 4A may be sufficient for normal uses even with more than 4 USB 3.0 devices plugged in.
  • Power brick compatible with Australian power outlets. We use 240V/50Hz, while the UK, if I understand correctly, uses 230V/50Hz, so a UK brick would be fine for my purposes, as I could just use an adaptor for the plug.
  • The vendor of course must be able to ship to Australia.
I've had a tough time finding USB hubs with the above characteristics here in Australia. 4 port USB 3.0 hubs are common, but anything more is difficult to find here.
I'm looking at this, because I've just bought a new PC, and unlike the previous one, this is a laptop PC (running Windows 8.1), which I plan to have semi-permanently plugged in at my desk at home. The laptop has 2 * USB 2.0 and 2 * USB 3.0 ports, so I want to increase the number of ports.
I'd appreciate any information :smile:.
ColinJ
Puzzle game procrastinator!
Would this one do?
TheDoctor
The TerrorVortex
The UK doesn't, strictly speaking, use 230V. That's a nominal figure for us and Europe.
We actually use 240V, Europe uses 220V.
The tolerances are designed such that European stuff will work fine in the UK, and vikky verkey.
Shut Up Legs
Shut Up Legs
Down Under Member
This might do, but I don't know if the power supply will be OK.
http://www.ebay.co.uk/itm/7x-USB-3-..._USB_Cables&hash=item4d156c000d#ht_9458wt_964
BTW, why not just use two four port hubs, one slaved off the other? That might give you a whole lot more choice locally.
I've considered that. Plus, it makes no difference whether I
  • plug the 1st 4-port USB 3.0 hub into the PC's 1st USB 3.0 port, and the 2nd hub into an output port of the 1st; or
  • plug both hubs into a USB 3.0 port on the PC.
The end result is the same: instead of 2 USB 3.0 ports, I end up with 8. In the former case, of course, I have 1 USB 3.0 port available directly on the PC, in case I have a device that works best that way.
As for the answer to your question: convenience, that's all.
slowmotion
Quite dreadful
lost somewhere
victor, I don't know what the desk/table with your PC looks like, but mine is a spaghetti of cables, PSUs and junk. A couple of four port hubs would hardly seem to be inconvenient round here. They would simply merge into a cluttered background.
