Geoff Crowther
"... travel far, not fast", Ted Simon
- Hayfield, High Peak
Hi all
Looking at how I keep the tyres at the right pressure on a long cycle tour.
If I buy one of these:
http://www.ebay.co.uk/itm/ALLOY-PUM...KE-TUBE-VALVE-ADAPTOR-NOT-BRASS-/261536370999
will I be able to use a pocket sized car tyre pressure gauge? I suspect not cos there'll be no centre pin for the gauge to press down.
Any other suggestions on how I keep pressures right or am I just worrying unnecessarily? Should I just use my thumb? BTW the bike's a Thorn Sherpa running large, 2.5" wide tyres at around 50-55psi. I use a Topeak Mountain Morph pump.
Thanks in anticipation folks.
Geoff
Geoff
once a month or maybe a little more often i deflate both tyres down to almost flat (leaving just enough air in so i don't get a pinch puncture) reseat tyre bead properly and reinflate to correct pressure on pump gauge. probably not needed but only takes a minute or two and gives me peace of mind TBH
