themosquitoking
- Spain
If you get to the third largest cog in your big ring time to change to the small one. If you get to the third smallest cog on the small ring time to change to the big one.
depends if you know which gear you are in, I don't always(!). Much simpler to use big ring except in uphill areasIf you get to the third largest cog in your big ring time to change to the small one. If you get to the third smallest cog on the small ring time to change to the big one.
It's just a matter of using the gears
I originally years ago had a 10 speed road bike - gearing not dissimilar to what is now called a compact
When I came back to cycling, I got a hybrid, a triple amd got used to using middle ring mostly
Now got a road bike and as I said use the large ring except for uphill
I have a 32 on the rear so I have nearly the same range of gears as the triple, but 2 rings and 9 cogs on the back instead of 8.
It's not hard to get used to
I have 50/34 on the fron and 11-32 at the back so even a tough hill should be OKWhat gearing does your current bike have up front?
very big thighs if sir Chris is anything to go by!It's a mystery how track riders manage a standing start with only one gear.....
Strictly speaking that is not a double, it is a compact. A double in my book has a minimum of 39t inner, 42 is much better though as you don't need to worry so much about changing up to the big chainring. Quite why the trend has been to increase the big chainring on a standard double from 52t to 53t is beyond me, way too big for most unless you are racing or TT'ing.
For safety's sake, I don't want to take 10 seconds to get to 20mph.
Which you will do, if you use the bike's gears like a car.
