V brake, missing spring tension screw.
Sara_H
Hello all,
I've changed the v brakes on my folding bike this afternoon. Was feeling very pleased with myself until I came to adjust the spring tension on the front brakes to find a screw missing.
Can I replace this? Or do I need to replace the lot?
Ah. Unless you can find one in a spares bin, then you'll need new v brakes. Worth a call into a proper LBS.
Sara_H
Sara_H
No one size does not fit all. You might find something that fits. Either that or start searching the floor where you fixed the bike
How do I know what to buy then? Do I have to take the old one off and take it to the shop for a match?
Pauluk
Leicester
I usually remove mine and replace them with stainless steel grub screws so that I can adjust them with a hex driver. Think they are just a standard 2mm X 10mm grub screw. unless they are completely different on a folding bike, just go to a local screw shop or look online. Cost about 10 pence.
Andy_R
Hard of hearing..I said Herd of Herring..oh FFS..
County Durham
Which manufacturer and model brakes are they? If they're Shimano, have a look in shimano tech docs for the part.
Pauluk
Leicester
Just had a look in my spares box. I think the screws are more like 3mm (or 4mm) by 8mm long. Either way, they are as cheap as chips. I bought a dozen for about £1. Just take one out and take it to a shop for them to size. I'm lucky here in Leicester, we have a shop specialising in screws and bolts of every description.
Sara_H
Sara_H
[QUOTE 3140018, member: 45"]Follow fossy around until he locks his hike up and goes inside, then nick his screws.[/QUOTE]
Thats given me evil ideas.
