Drago
- The Urban Fringe
I think we kjow that any rational, sane man would give the van priority.
I glued the mat and the ply then stuck it all together on the drive...
I also popped the leisure battery back in at this point to check it still fit with the extra thickness of rubber under it...
Anyway, I ran the wire to the starter battery and realised I'd run out of crimp terminals so couldn't connect it
D'oh... I've ordered more and left it coiled, ready to connect to the battery via an inline fuse.
I'm dangerously close to having the 12v side of things up and running now
I’d be careful running that battery cable through that sharp hole in the crossmember, that could be nasty if the insulation rubs away.
I've also connected up all the other bits and pieces to get the solar side of things working, including the panel itself - it's all up and running now!
Once thats done, the whole 12v charging system will be finished so I can start on the load side of things
Once I've got a bit more done I'll tidy the cables up a bit, just wanted to see it working before I put too much effort in to neatness
Yes they are, the battery is filled with a sulphuric acid gel and cannot leak unless you smash the casing, also OP check the charge requirements, there's something in the back of my head about the charge characteristics of these type of batteriesI know it's a none spill battery but are they really OK on their side?
Can I Use My Battery Charger on AGM Batteries? (mkbattery.com)Yes they are, the battery is filled with a sulphuric acid gel and cannot leak unless you smash the casing, also OP check the charge requirements, there's something in the back of my head about the charge characteristics of these type of batteries
It's getting rather nice for a naff old van
Love it!
So is the rear going to be purely bike storage, or will there be a mini sleeping berth as well?
Most self build campers make them out of wood but I'd be tempted to weld it up from steel tube for the challenge.The plan is to engineer some sort of folding bed/sofa type arrangement, so it can be completely stowed flat against the wall with the mattress removed when I need to use the van for general vanning, then fold down as a sofa when I want to carry a bike around and have somewhere to sit, then fold down further in to a double bed so we can use it for the odd camping trip etc. I have started designing it in my head, but will start sketching in CAD at some point soon to work out the critical geometry and decide whether its going to be sensible to attempt itMost self build campers make them out of wood but I'd be tempted to weld it up from steel tube for the challenge.
I've got a small 12V Cello TV on the way as suggested by @BoldonLad, the aerial for which arrived today. I've also got a camper specific mount coming that has a locking bracket so it can be stowed flat against the wall without swinging around as I pinball my way down the lanes 😄
All very exciting...
