I've spent several more hours on the van over the last few days and some good progress has been made, despite the weather doing its best to thwart me
The rush is due to Mrs Bssll wanting to use the van for a festival this coming weekend - I've known this for months, but other jobs have had priority until now. Yesterday I realised I was running short on time to finish the bed so made the decision to concentrate on two of the three frame sections. Since it's only her sleeping in it this weekend that'll be plenty big enough, and it means I don't have to faff around building the side supports for the nearside yet, just a few legs. It also reduces the amount of welding and painting by a third which is pretty handy
First step was to weld the last few hinges on so that all the parts fit together and I could test fit them before I put one of the frames to one side. Here it is in the seat position.
And here it is folded out as a bed
And finally here it is in the stowed position
Lots of brackets and fittings required to hold it in these positions but that can wait until after it's been trialled this weekend 😊
Happy with that I cut and welded cross supports in to the two remaining frame sections, then cut square tabs to put in each corner to support the plywood that will form the platform. Once these were all welded up I painted the bits black and left them overnight.
This morning I started again on the 12V electrics - I'd got the lights and charging side of things working a while ago, but the 12V power was still missing and the wires for the stereo remote on/off and fan were still to be done. I also needed to fit the TV so I knew where the socket would need to go. I didn't take many photo's during the work, but here is the TV fitted on it's special travel bracket that locks it against the wall...
I'm waiting on a few connectors to finish the TV install - the SCART lead will provide the audio out to the stereo in the front but I need a new adaptor as the one I have is too bulky to fit
I also need an antenae connector as I had to cut the one off the aerial I bought to run it through a grommet from outside
I've also bought a signal booster as the reception is rubbish in these parts. I'll report back when I've connected it all up, hopefully I'll get at least a few channels
With the power run back to the leisure battery for the TV I tirned my attention to neatening that corner of the van up, adding a few more power sockets and finishing the stereo wiring. I cut the original hardboard panel to cover most of it, I'll build around the battery another day but will insulate the +ve terminal before the weekend to prevent accidental sparks
In the top left of the panel are two 12V sockets, then a switch to remotely turn the stereo on and off, and a switch to turn the ceiling fan on and off. For now the fan wire is dangling from the ceiling as there is no ceiling fan
I'm in two minds about fitting it before the weekend in case I don't seal it properly and it leaks
Anyway, with that panel fitted it meant I could refit the now painted bed/seat bits 😄
So here we are, this is how she stands this evening:
Before she leaves on Friday I need to finish the following:
- Build some legs to support the frame sections.
- Drill and screw the ply boards down to the two finished frame sections - I've already cut the ply to fit.
- Fit the ceiling fan?
- Give it a good clean
If I finish that I've also bought the ply to board the ceiling and walls before I insulate and line the inside but I suspect I will be doing that at a later date
