TissoT
- The Home of British cycling
I run a Building/joinery company if I tried to charge what a locksmith charges for the length of time they are there
I wouldn't be in business.
Its a easy fix snap the key off in the lock and theres a bolt in the side of the door (Pozi) that holds the barrel in take it out and replace with a new barrel
Thats RightIf the key is jammed in the lock, you wouldn't be able to rotate the cam in order to allow you to push/pull the barrel out.
Master Degree?Takes a lot of studying to be a locksmith...
He probably went to Yale
Maybe you should retrain, I will be charging upwards of a £100 per hour if you only count times on tools myself at times today.
We do pretty handsomely in regards to pounds shillings and pence.Maybe you should retrain, I will be charging upwards of a £100 per hour if you only count times on tools myself at times today.
Locksmiths work is feast and famine. As no one plans to use a locksmith until they need a locksmith, so they can’t plan work ahead and customers can’t get estimatesI run a Building/joinery company if I tried to charge what a locksmith charges for the length of time they are there
we used one about 15 years ago, he told me that a large percentage of his outgoings was advertising, to get to the top of Yellow Pages.
The business model must have changed now but they still need to be easy to find in an emergency.
what he did took less than 5 minutes but I couldn’t have done it.
But retrain as a locksmith, I prefer a good nights sleep.
