weight difference between shimano compact chainset and a 105/ultegra double?
jimboalee
Solihull
Ribble usually state the weights of the products.
Garz
Squat Member
Down
Then you put your water bottle in the cage and the saving wasnt worth the money! :biggrin:
There's less than 100g difference between a triple and a double.
A triple has that extra ring, 5 extra bolts, more material on the spider...
So the difference between a compact and a double must be - ooh 15-20g ?
Ah yes, here we are...
http://www.ribblecycles.co.uk/Produ...rodPerPage=999&CatID=65&BCat=1,65&RootCatID=1
- Ultegra 6603 triple 922g
- Ultegra 6600 double 833g
- Ultegra 6650 compact 848g
The compact is heavier than the double !!
- Stronglight Impact 2 triple 725g
- Stronglight Impact 2 double 675g
- Stronglight Impact 2 compact 675g
Compact & double same weight
