Weight Distribution on Electric Cars.
simongt
Norwich
Last night a colleague got himself stuck in a muddy car park in his EV.
We pushed him onto solid ground nae bother, but it was when I saw the front drive wheels failing to grip, it occurred to me that because the battery unit is under the floor of the passenger area of the car and therefore spread over a much larger area and the electric motor is much lighter than an ICE engine & gearbox, then there's no appreciable weight directly over the drive wheels to give any appreciable advantage unlike an ICE car.
Or am I missing something - ? :whistle:
Could be, but any car can get stuck especially wide tyres designed for tarmac, not mud.
Widnes
Theres no perfect solution for all scenarios.
Low and between the axles is ideal for most purposes, better than up front or even ahead of the front axle line, but may not be ideal in this scenario.
Selecting the appropriate driving mode would have limited both slip and torque and helped get your chum out. He needs to read the manual.
Reminds me of a friend of mine that was a copper
he said he had "rescued " lots of drivers that were stuck in ice/mud
They said he must have had extra driving training due to being a fully trained pursuit driver
which he wasn;t - he was "just " a normal copper driving around in a basic Fiesta
he just knew how to drive because his Dad taught him and he had a brain!
Drago
My Dad was a RoSPA observer and taught me to drive. I've regaled you good folk many times with tales of his teaching technique with me, but suffice to say I've nefer been daft enough to try and park a car on any unsuitable surface.
Widnes
It is sometimes as simple as knowing where the drive wheels are and reversing into a parking space if the far end of it is downhill and icey
saw that once on a field used as parking to watch a car rally
I reversed in to keep the front drive wheels on good grass
several others went in the wrong way and the people who knew what they were doing had to pull them out
it's called thinking
presta
My Viva, Capri, Cortina, TR7 and Carlton had no (traction) battery, and a petrol engine at the far end of the car from the driving wheels. Front engine RWD was the most common layout at one time.
simongt
simongt
Norwich
And the 'old fashioned' tip of always leaving the car in gear when parked in case the handbrake fails.
Still do it instinctively even after fifty three years of driving - ! :laugh:
Drago
Wheel turned into the kerb.
presta
It might make you feel better, but it doesn't work. It only holds until the compression in the cylinder has had time to leak past the piston rings, then the car lurches forward until the next cylinder catches it. Repeat for each successive cylinder until the handbrake's applied. Engines are designed to maintain compression for the few milliseconds it takes the piston to travel from one end of the cylinder to the other, not indefinitely.
(I had another occasion when the car also started unparking itself from the space I'd just put it in as I was about to walk away, but that time was when the rear wheels were slipping on the snow instead.)
wafter
Oxford
No matter where the mass is, it still has to be reacted collectively by the wheels. All depends on the layout of the vehicle in question; which wheels are driven etc.
Gillstay
When I used to take my Berlingo down the woods if it rained and got a bit slippery , just by putting a load of timber and the tools in the passenger footwell often gave enough grip to get out.
