What has happened to my spokes?
winjim
Just before Xmas I swapped my cassette over. It wasn't quite shifting right so today I took it off and put it back on again to make sure everything was aligned properly. While it was off I noticed big gouges on all the outer spokes on the drive side, behind where the cassette goes. What could be causing this? They look fresh. Surely it can't be the cassette as that sits a couple of mm out from the spokes, and anyway these gouges are within the radius of the largest sprocket, if you see what I mean.
What's caused it, should I be worried and am I going to need my rear wheel rebuilding?
RebornBumbler
Barnstaple
Hard to be sure, but it looks like only minor scraping to the black finish - perhaps you got a bit of wire caught round there at some point ?
cyberknight
Do you use the lowest gear ?
Im guessing something to do with the low stop but the rear derailleur would catch it higher up the spoke so is the chain catching the spokes ?
winjim
winjim
It doesn't photograph too well but it's not just scraping on the black finish - there's definitely jagged metal.
winjim
winjim
I did consider that, but then the chain would need to be between the sprocket and the spokes.
winjim
winjim
I don't think the chain could have come off, damaged the spokes in that way, and then come back on although there has been some odd clunky shifting on the large sprocket. The damage goes right down to the level of the hub flange, and that's a 30 tooth sprocket. This photo is with the cassette installed:
Maybe I should've left the pie plate on.
winjim
winjim
Old cassette had pie plate in place so it's happened since the swap. Working assumption has to be chain jumping off and on again I think, although I'm still skeptical...
I've been meaning to get into wheelbuilding so I guess I'll start by having a go at respoking this one.
raleighnut
Its easier to do them one at a time and then you can avoid needing to retrue the whole wheel, just get each one right before going on to the next.
