Cycling fast through a thunderstorm results in you having more chance of being struck by lightning:
If you move a metal object through a magnetic field, then if creates a potential, and therefore current flows. It is the principal that all generators work on.
An electrical charge causes a magnetic field around it - see electromagnets.
So, with the air ready for an electrical storm and all charged up, there is a magnetic field all around us. Passing a large metal item (say a bike frame) through this will cause it to get charged. The quicker the movement, the larger the charge. One end of the bike will be more negative, and one more positive. This will increase the potential from the charged clouds at one end, and a bigger potential across the same distance will mean that a discharge is more likely. Hence if lightning strikes, it will hit the bike, rather than the lesser charged surroundings.
Only two ways round this. One is to cycle slowly. The other is to get a carbon bike that will not generate a potential when moving through a magnetic field. Cycling slowly is clearly not an option, as you are getting cold and wet.
And that is the excuse that I am giving my wife this evening. Hopefully she won't see the holes in the physics.
