"A bolt of lightning is a current that can generate up to 300,000 Amps."
Er, no ... it
is a current of up to 300,000 Amps!
That looked fun though.
In the 1970s, I was shown round some of the electrical engineering labs at the then Lanchester Polytechnic (now Coventry University). They had some pretty scary equipment in the bowels of the building!
In one of the labs, I watched an experiment being done on the kind of porcelain insulator stack used to hang high voltage cables from pylons. The experiment consisted of applying several hundred thousand volts across the stack and then spraying it with salty water until
'something' happened.
I wasn't quite prepared for what the
'something' was! (I was a naive 18 year old at the time ...
I watched the kV meter reading creeping up and could hear disturbing hums, crackles and hisses being emitted from the insulators, Then they started to emit an eerie glow. The whole gubbins was housed in a big wire mesh cage and I knew that we were safe but I wasn't quite prepared for the emotional impact of standing 10 feet away from what was effectively a mini lightning bolt suddenly flashing over!
I leapt about 3 feet in the air and gibbered like a very gibbery thing while the lab technicians almost wet themselves with laughter. Apparently, everyone reacts the same way the first time they witness it!
It certainly gave me more respect for lightning and I do my best to steer clear of it!
