wheels
Young Un
Worcestershire
Clinchers are like normal tyres that will be fitted to your road bike: they have a bead on the tyre which hooks into a pip on the rim and these tyres require an innertube. Tubular tyres are like anlinner tube and tyre sown together to make a cyclinder that does not have this 'bead' meaning that the tyres must be glued or taped onto the rim. Tubulars roll a lot better making you faster and so are used by many a tt'er (lighter aswell) but punctures are a nightmare and can be costly!
Hope this helps
clinchers need an inner tube, and the tyres have a bead which 'clinches' the rim of the tyre. Tubular tyres have a built in inner tube, and so need no mechanism to attach the tube to the tyre.
youngoldbloke
Its getting even more complicated nowadays as tubeless tyres are being introduced (like car tyres), these need another type of rim, but some top-end wheels are now available with rims that can take both tubeless and clinchers. Tubulars cannot fit onto a clincher type rim and viceversa. A tubular rim is smooth and hollowed on the tyre-side to allow the tubular tyre to be glued to it, rather like a hollow fat rounded, filled in, C in section.
