Replacing the freehub, checked the decathlon website and they don't have any freehubs available for saleAre you replacing the freehub on the hub or the cassette. If it's the freehub, you are best asking Decathlon if they have spares, as they are a generic wheel and may or may not have spares. Your best option might be to remove and service the freehub.
Yep the freehub is goosed - the cassete is loose on the freehub body (which is pitted with corrosion) - it's the bike I use for commuting to workprobably only decathlon can tell you what freehub is compatible, unless you can tell from removing the existing freehub and having a look.
Is it defo the freehub that is goosed and not the wheel bearings?
or perfect excuse for a new set of wheels5 years isnt a bad shift for in house stock wheels
Out of interest what would I expect to pay for a pair of wheels - looking at the cheaper end of the marketprobably only decathlon can tell you what freehub is compatible, unless you can tell from removing the existing freehub and having a look.
Thanks mate, much appreciatedhttps://www.spacycles.co.uk/m10b0s205p4277/SHIMANO-WH-RS100-Front-and-Rear
bomb proof commuter wheels with serviceable hubs.
You really can't go wrong with Shimano hubs for commuting, the fact they are loose bearings and you can properly adjust the preload and regrease and service easily makes them perfect.Thanks mate, much appreciated
