snailracer
One more to add to your list, when you are in primary, motorists often have to slow down and wait for a passing opportunity. This means they pass you at a lower speed, and you can easily hear their engines revving up as they overtake which gives you an idea of where they are.To elaborate-
I get a lot more incidents being cut up when I'm over on the left than I do stroppy drivers being annoyed when I'm in primary.
- When you're in secondary, vehicles are more likely to try to 'stay' in your lane when they pass, so you're more vulnerable to close passes. In primary, they've got to cross the line anyway and so they're more likely to give you room.
- In primary, you'll stop a proportion of vehicles from trying to pass you at all. Personal safety when you're on your bike is as much about controlling the space around you as anything else.
- As has been said, if a driver is going to pass you close he can and will often do this wherever you are in your lane.
- If you're in primary, you've got a safety zone when he does this.
- In primary, you're easier to see.
- In primary, (in my experience) you generally get more respect as you are seen to know what you're doing).
If more cyclists rode in primary more often, motorists would get used to it and not get annoyed.
