Drago
- Suburban Poshshire
Got a Homehub 6 at the front of the house, get a signal fine at the end of the back garden 60+ feet away.
I have a home hub. Not sure on model but had for 9 months.Got a Homehub 6 at the front of the house, get a signal fine at the end of the back garden 60+ feet away.
They are out of stock but I have just received an email from 7DayShop.com advertising them for £3 less and they are in stock - DETAILS.Just came across yet another solution, which does not use up an electrical socket. Bit more work to instal them however:
https://www.mymemory.co.uk/british-general-wi-fi-extender-switched-double-socket-usb-port-white.html
I got TP links a few years ago (thick stone internal walls) - work a treat, only have to be via same consumer unit (mine are on different ring mains).I want a booster, but was given conflicting information in a shop.
The one I was shown had two boxes that both plugged into the mains, and I was told they'd need to be on the same circuit to work.
When I asked, 'on the same actual ring main, or just the same consumer unit,' I couldn't get a straight answer.
Assuming different rings, if that matters, what do I go for?
Cheap end should do the trick.Having Googled TP link I find prices from £25 to £150, how much do I have to spend for use in an average sized semi?
