width of chainsets
Discussion in 'Bicycle Mechanics and Repairs' started by cyberknight, 4 Mar 2018.
  1. cyberknight
    cyberknight Legendary Member
    South Derbyshire
    Does the width of a chainset chain rings vary ?
    Put a "cheap " fsa powerdirve chainset in and although i have a 10 speed microshift FD the chain rubs in either the top or bottom gear .
    Cant remember it rubbing on the hollowtech 2 BB fsa chainset
  2. Cycleops
    Cycleops Guru
    Accra, Ghana
    I imagine you mean between the two/three chainrings. Seems like they do , have you compared them? You just need to adjust the h/l screws.
  3. OP
    cyberknight
    South Derbyshire
    Nope double to double
    both compact hollowtech 2 to fsa powerdrive.
    LBS claims my front mech is 9 speed but it is 10 speed although on further reading microshift is a bit pants .
  4. OP
    cyberknight
    South Derbyshire
    asking on a boardman facefluff page and a tech has basically told me the microshift mechs are renowned for rubbing
  5. chriscross1966
    chriscross1966 Senior Member
    Swindon
    Yes, each company has their own take on the perfect chainline, though some of them are pretty close.... I have endless fun putting aftermarket (generally Campagnolo Ultratorque) chainsets and bottom brackets in my Bromptons...
  6. si_c
    si_c Veteran
    Wirral
    If you've changed the chainset, then it is likely that the position is subtly different from the previous one, so you may well need to adjust the high-low limit screws, and possibly the cable tension to remove the rub, might take a bit of trial and error.
  7. OP
    cyberknight
    South Derbyshire
    Done that , it either rubs top or bottom, cant get it right .
    On further reading the FD is a microshift jobbie that is renowned for being a bit pants so I am on the hunt on fleabay for a sram FD to match the rest of the groupset .
    si_c likes this.
    Dismiss Notice
