lulubel
- Malaga, Spain
With all due respect to the op she is 58. What kind of improvements are you expecting?
Improved fitness, presumably, which happens when you exercise regardless of age.
^^ What Lulubel said.Improved fitness, presumably, which happens when you exercise regardless of age.
Haven't you heard? Life starts at 50!With all due respect to the op she is 58. What kind of improvements are you expecting?
That's fine, I'm not afraid of taking a bike apart, used to do it a lot in my teens.For example; the description of the bike online is slightly vague, but it is likely the bottom bracket assembly (crank shaft & bearings) will be the older cup & cone type, which will need periodic cleaning, regreasing and adjustment plus occasional replacement of the ball bearings.
Ah! I meant to ask you about that! Forgive me not knowing the right terminology but when changing up the sprockets on the crank it generally takes a bit of jiggling the lever to get the chain to shift. Changing down isn't a problem. The sprockets on the back wheel seem to be ok.The gears will tend to need more frequent adjustment to keep them running sweetly and so will the brakes.
A customised jalopy! I like the idea.There is nothing to stop you fitting better parts to the bike as they wear out, and this is what I've done with my current cheap knockabout bike.
Oi, watch it chuck, I'm not decrepit you know!With all due respect to the op she is 58. What kind of improvements are you expecting?
Excellent! Really the main thing you'll find has changed fairly recently is that current bikes need more special tools. If removing the cranks to service a bottom bracket you'll need a crank extractor and if you decide to fit a cartridge bottom bracket you'll need a bottom bracket tool. They don't have to be from Halfords - just examples.That's fine, I'm not afraid of taking a bike apart, used to do it a lot in my teens.
Did I mention that in those days I had dreams of being a track cyclist? Didn't need quite the highly-specialist kit in those days and the local track was a banked tarmac strip around the edge of a cinder running track but I was saddled with risk-averse, over-protective parents who adamantly refused to have a bike with so much as drop bars. I got my thrills instead by taking my four-gear donkey bike to the highest point in town and pedalling furiously into the valley below. No helmet of course. Oops! But I got away with it, time after time.
For this, if it is happening changing up to the middle and big rings I'd suspect the cable is just out of adjustment. There is a barrel adjuster on the left shifter which will need to be turned anti-clockwise (looking from the cable side) until it shifts properly.Ah! I meant to ask you about that! Forgive me not knowing the right terminology but when changing up the sprockets on the crank it generally takes a bit of jiggling the lever to get the chain to shift. Changing down isn't a problem. The sprockets on the back wheel seem to be ok.
I don't feel like a bike really belongs to me until I've modified it to my own taste.A customised jalopy! I like the idea.
Haven't you heard? Life starts at 50!![]()
[FX: vigourously slaps RideLikeTheStig]
.He's a glutton for punishments isn't he!Thats what they say, but in reality it ends at 50 for most![]()
yes, me too, batter him on the head, even though I'm only 49 and a halfHe's a glutton for punishments isn't he!
[FX: vigorously slaps RideLikeThe Stig]
: RideLikeTheStig:
Well, one week on and I DID IT!My short term ambition is to get to Ulverston but I don't feel as though I'm going to make it any time soon.
or, even better, search for "slime" for your tyres.
Shame about the puncture though.
May I point out that this rather portly over-50 is hoping to small down.big up the over 50s
