Win 7 upgrade
gf1959
As a project i'm thinking of upgrading my second pc to Win 7,and the m/board too.
Currently it runs XP. My question is can you upgrade the whole lot at once,m/board and OS?
Or is best to do them separately,and if so in which order?
Any advice appreciated.
Norm
I don't think there's a direct upgrade path from XP to Win7, so it would be a fresh installation.
As that's the case, I'd do the whole lot at once.
G
gf1959
Thanks,yes it would be effectively a fresh instal,i understand it would wipe xp which is fine.
Yes, do them together. If you do them separately, I'd do the MB first and then the OS as Windows 7 (I think) might get picky about which PC it's installed on as an anti-piracy measure. So if you install it, then change the MB, it might think it's a new PC. Which is fine - you are allowed to install it on your replacement PC - but it might mean more effort.
If the Windows 7 OS is OEM you will have to get a new activation code should you subsequently change the Mobo - a bit of hassle as you have to phone MS up and convince them that it is a genuine replacement.
If your 2nd pc is a bit on the ancient side I'd also replace the PSU and you need 2GB RAM I believe.
G
gf1959
Thanks everybody,looks like doing them together is the way to go then. I'm only upgrading the mbo cos it has less than
2gb of ram so win 7 probably wouldn't run very well on it.
Carwash
Señor Member
Visby
That makes sense if all the RAM slots are filled to their maximum capacity; but otherwise, why not just buy more RAM? Much cheaper than a new motherboard, and easier to install as well.
G
gf1959
It's an old IDE mbo,only holds 2gb,i doubt i'd get it to run on that(unless anyone knows different?)
