- Inside my skull
Were you cycling up Everest in the Jet Stream then crashed into a crevasse on the way down?
Nothing stopping x being 2 or 3. Y = x^2 is an exponential function as is y=x^3. Y = x^4 etc.
@DaveReading is correct
The graph illustrates how exponential growth (green) surpasses both linear (red) and cubic (blue) growth.
In the case of air resistance,
Resistance F = KV^2 a power relationship
An exponential relationship would be of the form F =K^V
See:
http://www.softschools.com/formulas/physics/air_resistance_formula/85/
In a different thread, @srw and I have just been confused with each other. One of the differences is that he is a mathematician and I am a physicist. I'm going to take a punt that neither of us knew that power and force have different meanings in maths and physics (but that we both knew that exponential is used colloquially in a way that differs from the scientific meaning).You are mixing the meaning of power and force in Physics with the different meaning in mathematics. But anyway none of this is helping Accy answer his question. The true answer is probably he beasted himself uphill and was then too tired to pedal downhill.
they're my favourite sort of facts.Particularly when they’re made up...
I don't think they do - because in maths they're only used in mechanics, which is basically physics by another name.In a different thread, @srw and I have just been confused with each other. One of the differences is that he is a mathematician and I am a physicist. I'm going to take a punt that neither of us knew that power and force have different meanings in maths and physics (but that we both knew that exponential is used colloquially in a way that differs from the scientific meaning).
If you create a room with zero gravity I’m pretty sure if a feather and a brick were dropped at exactly the same time, they’d both touch the bottom at exactly the same time. I haven’t done physics for over 25 years mind.I don't know. I'm waiting for a CC scientist to come on and explain it to me. I think it'll take someone with at least a degree in Physics,or something like that.Mind you,the other week i said that going downhill on a carbon fibre bike was harder than on a steel one, as with it being lighter it won't descend/fall as fast. Someone down my local pub after i'd made the comment told me that all objects descend/fall at the same speed no matter their weight or shape. I still can't get my head round or accept that one.
Fixed zero-g for vacuum.If you create a room with a vacuum I’m pretty sure if a feather and a brick were dropped at exactly the same time, they’d both touch the bottom at exactly the same time. I haven’t done physics for over 25 years mind.
Almost put that too. Thanks.Fixed zero-g for vacuum.
Brian Cox has done this at NASA. It was really weird to watch...
An even simpler test is to get two identical umbrellas, open just one and drop them both. I very much doubt they'd hit the ground at the same time.The simple test is get a small 1kg metal sphere and a 1kg Piece of cardboard with a huge surface area. Drop both from 100m up and they will not hit the ground at the same time.
