Spinney
Bimbleur extraordinaire
- Back up north
Hi all
I got the seat post shown below with my new bike. All was well until I tried a different saddle. I could ride for up to 30 miles, but at some point the saddle would become loose (not enough to fall off, just to move a bit - offputting and uncomfortable). I'd tighten it up and it would happen again, anything from 5 to 30 miles later.
Am I just not doing it up tight enough? I've seen new versions of the seat post in a bike shop, and I am pretty sure that I have not lost a washer or other part when faffing with saddles.
It seems to come loose more readily with the saddle in a slightly tipped-forward position (I wanted to try it tipped forward a bit to see if it was more comfortable). This means that I do not seem to be able to get the full range of adjustment from it.
This particular design, unlike others I have seen in bike shops, has no 'teeth' between the post itself and the bottom of the two bits of metal that grip the rails on the saddle. Is this partly why it is difficult to do it up without it slipping.
And if I do end up replacing it - any recommendations as to the best type? One that stays done up with the amount of tightening a female can give it with a multi-tool, ideally! Not that it will need changing often, but I am still working on finding the best saddle/saddle position for comfort.
Thanks
Spinney
Thanks
Spinney
