I have just found another new way of treating it, drug free too:
* Dissolve 1/4 teaspoon of pure salt (no additives, obtained from Safeway or pharmacy) in a tumbler of warm clean water (any question of the water, use distilled).
* Apply the open top to the upper lip as it meets the nostrils and tilt the head back allowing the water to run into both nostrils. In this position, sniff the saline up through the nose, and out through the mouth.
* When it does, bend the head into the washbasin and blow out the contents of the nose. Observe the colour of the discharge.
* Empty the tumbler in this manner and repeat until discharge is clear.
This rinsing should be done minimally morning and night and 10X plus throughout the day if consecutive washings are discoloured. The aim is to have consecutive washings produce a clear discharge. When discharge remains clear, reduce the frequency to twice daily.
This procedure is very comfortable, provided the concentration of salt solution approximates 0.9%. Too low concentration produces a sharp severe pain. Too high produces an astringent salty taste. Rinsing should commence immediately with the onset of any cold symptoms including an itchy throat and in most cases, no further treatment is required.
