Would you care to share the link?
http://www.wugfresh.com/nrt/
I already had the drivers installed on my Nexus from when I'd been messing about (I think these are the USB driver and fastboot or something), so I didn't have to click on that field on the program.
Basically,
enable USB debugging on the tablet. Settings/About Tablet/ go down to the Build number, tap it 7 times, then use the back button once, tap Developer Options/Enable USB debugging. When you connect the tablet to the PC (running Nexus Root Toolkit) a little box will come up showing the Nexus' USB debugging code or something, just click Allow.
On Nexus Root Toolkit,
Click
"Full Driver Installation Guide and Instructions"
Click
"Unlock Bootloader"
Click
"Flash Stock and Unroot". Select to download and install Android 4.4.4 KTU84P, or you can try any, but I believe this is the best for the 7.
Click
"OEM Lock", this just locks the Bootloader again (you won't see the unlocked, lock every time the tablet boots up0.
I believe that the program works on most Nexus products. Maybe it's more than 1 click, but way easier than the other methods, as all the complicated commands etc are done by the application. You could also use this to Root your tablet if you wanted, but the Nexus 7 isn't full of annoying Bloatware, like Samsung products, for example, have been in my experience.
All of the steps above take a bit of time for the program to do it stuff, and it will obviously wipe all data. The only thing that you will need to do is select
"Yes" on the tablet screen when asked about unlocking Bootloader. The program tells you all this though. When the Nexus is in Boot mode, the vol UP/DOWN buttons are scroll, The POWER button is enter. I just had to press the Power button, as
YES (to unlock) was highlighted.
Note: You'll still get the annoying message to upgrade your software. To stop this irritation,
Long Press on the
notification itself. On the App information screen
Un-check, Enable Notifications. Or it could be disable them, it's easy though. I'm not sure if this disables all update notifications, but just check manually every so often if it does.
