Pop Quiz: Priorities and assigning fault in an RTC
Who is at fault in this collision?
  • The emerging driver
  • The flashing driver
  • The motorcyclist
  • Nobody
  • Everybody
Results are only viewable after voting.
Thatcher.
mjr
Emerging driver most at fault, but flashing driver shouldn't flash as a come-on and motorcyclist should be watching out for this sort of common nobbery, so everybody a bit.
summerdays
Cycling in the sun
Bristol
I went for all, emerging driver should check it's clear all directions, I was told that you shouldn't flash your lights to tell someone it is ok, and the motorcyclist if filtering needs to be aware that other drivers aren't necessarily expecting him/her to be there and so should only proceed cautiously especially as your view will be blocked by the traffic you are filtering past.
  • Like
Reactions: _aD
deptfordmarmoset
Full time tea drinker
Armonmy Way
I'd say it was the emerging driver who was at fault but I have heard that the flasher may be considered to be at fault. But that's a highway code thing about the meaning of a flash. However, any imposition of the meaning of flashing to another road user needs to take into account usage, like that other system of signs, language. The meaning in everyday usage in just about every busy urban context is ''I'm letting you go first'' not ''You have priority'' or ''I'm here!!!'' So, I'll exonerate the flasher for not knowing what they might not have been able to know.
So, was it the motorcyclist to blame because he was not able to stop his/her vehicle in time?
mr_cellophane
Essex
I had a car pull out on me last week in a similar situation. The driver said it was my fault because she was waved out by a driver in the queue. The BC legal adviser couldn't help but laugh at that suggestion.
winjim
winjim
Smash the cistern
OK. Like most people, I thought that it was definately the emerging driver who was at fault. As pointed out upthread, the responsibility is on the emerging driver to ensure that it is safe to pull out. I also think that the flashing is misleading and that the motorcyclist should be alert and vigilant but those are really side issues.
However... that was not the assessment of the officer present at the scene. His conclusion? Nobody is at fault.
Nobody.
Now forgive me if I'm paraphrasing, I'm trying to be objective and not put words into people's mouths, but I may not be able to remember exactly. What he said was:
I've just got back from talking to the motorcyclist (who was in the back of an ambulance) and he claims it's the driver's fault because he (the motorcyclist) had right of way, and he's technically right, but he (the driver) has got to pull out some time. It's just one of those things. No further action.
@w00hoo_kent I think you called it right :smile:
Note OB's use of the phrase right of way. One for the pedants.
I'm not sure if the motorbike (it was actually a scooter) was filtering. According to the driver he came speeding down there... Similarly I don't recall if the driver was turning left or right. Might be worth noting they were both young lads so inexperienced.
So basically the lesson for us as cyclists is to be vigilant at junctions with minor roads, because he's got to pull out some time. :sad:
  • Like
Reactions: _aD
