11 - 34 rear cassette (11 speed)
Hacienda71
Can you really run anything less than 38t on a 130bcd set up? I always thought 38t was the minimum. Just curious. My Red setup is a 53:39 and there doesn't seem much space to go smaller. My 110 bcd is 50:34
J
jowwy
Not here offten enough to argue
I will check but im sure it says 130bcd...........if it is 110 then i can get small rings upfront
TheDoctor
The TerrorVortex
If its 130 BCD then 38T is the smallest. 110 bcd will go down to 34T. Well, 33T technically, but 33T chainrings are unobtainable and barely worth the bother.
Jerry Atrik
South Devon
When I was going on a similar trip my LBS put a Deore rear mech on my 105 set and changed the cassette down from 10 to 9 speed and 28 up to 34 and worked fine .
slowmotion
Quite dreadful
lost somewhere
It might be down to wrap capability of the rear mech
16+25 = 41 and i think the sram force long cage is 39
But if i can get it to work my legs will thank me for it in the alps
You can usually bend the official gear tooth rules by two or three teeth, I've found. You might not get TdF-slick changes, but if you're touring, who cares?
J
jowwy
Loads of 33t rings on wiggle and spa cycles for 110bcd
J
jowwy
Im running sram force 22
J
jowwy
Im toying with going 1x11........42 upfront and 11-42 rear with sram force 1 rear mech
Im not bothered about spinning out on the descents as i always freewheel if above 27mph anyway
