at a velodrome perhaps....Fulcrum 5's will take your weight no problem
I'm 110 kilo and run a 16 spoke front and 20 rear and on those wheels I ride VERY rough surfaces and they still are in perfect true but those are shimano wheels
I don't know that F5s will be significantly stiffer. F7s were certainly too flexy for me at 90kg.
Really well built 32 spokers will give you stiffness and longevity but not the fashionable low spoke count "look".
I changed out my F7s for handbuilts: Hope hubs, Ambrosio Excellence rims. 32 spoke front/36 rear and it was a better bike for it.
Novatec hubs (aka Ambrosio Zenith) if you want sealed bearing, Whatever you can afford in Shimano otherwise. Open Pro rims. DT Swiss Comp DB Spokes Should get you under £200 if you are canny about where you shop.
The school of hard knocks and bitter experience.Grumpy, can you lead me to the source of your information please as I would like to do a bit more research.
your call but here's what the Owners Manual for the racing 5's says...Must of bought one offs as mine have been grand for nearly threes years now. I'm 110kg and the roads around N.Wales take no prisoners
you'll find it here @screenman
- If you weigh over 109 kg/240 lbs we advise you not to use this product. Non compliance with this warning can damage the product irreversibly.
- If you weigh 82 kg/180 lbs or more, you must be especially vigilant and have your bicycle inspected more frequently (than someone weighing less than 82 kg/180lbs). Check with your mechanic to discuss whether the wheels you selected are suitable for your use, and to determine the frequency of inspections.
Mine lasted less than 500km. 95k - 98kg. Back on 36 hole three cross now.
