2019 Croix de Fer 10 brake calliper pin thing
Ajax Bay
East Devon
I have a set of TRP Spyre-Cs waiting to be fitted. The retaining pin is 28.6mm long so I think the item you linked to is the business. Can't quite see how the pin can 'ping off.
The pin diameter is 2.9mm and there's a slight groove so the clip must have to close to about 2.2mm (rough measurement into clip).
HTH
Venod
Eh up
Yorkshire
Is it just the clip that's missing ? a piece of wire round the groove in the pad retaining screw, twisted tight with a slight tail left on the twisted bit will serve the same purpose, its to stop the screw coming out, but I have never seen one come loose anyway.
