Actual difference = 2mm. Hype? No, definitely 2mm. When I switch anything from 22mm to 24mm I notice a difference of 2mm.
That's a better way of looking at it. The tyre's profile means that the contact patch is the same on a 25mm as on a 23mm but you're floating on a bigger cushion of air.Think of it more as a 10% increase/decrease in tyre volume (approximately). Then it starts to make sense.
Not according to Continental it seems.....
At the same pressure. That diagram is crap.
The 25m will give a slightly cushier ride than a 23mm as you can run 25mm at a lower pressure. The same was said some years back when 20mm became 23mm as the desired choice. It's probably down to our roads being crap. I used to TT on 18mm Tubs !!! Tiny !!
Yes: a more relevant diagram would have shown the contact areas when both tyres were pumped up to to the middle pressure of their recommend pressure range.At the same pressure. That diagram is crap.
