Dogtrousers
Kilometre nibbler
Maybe dumb questions but ...TBH - 9 speeds to me is only achievable in a few ways.
3x3. Where they add two more chainrings AND an additional sprocket and use a single speed rear wheel. This actually makes more sense than the 1x9 to me. Or at least feels more achievable.
Where would you put the front mech?
Would you need a longer chain tensioner?
Would folding be affected?
Interesting. As I don't know anything about hub gears my proposed solution to this kind of problem is generally to point at the hub and say "do more magic inside there".Giving the BWR a wider range would mean impracticable gear sizes internally. You'd need a very big sun and, given that the OD of the shell is limited, the planets would be too small - the ratio of a single epicyclic is given by the teeth of (sun+gear ring)/gear ring. The BWR already pushes it about as far as it can go.
You can use cascading gear trains but they are pretty inefficient. You lose at least 3% in an epicyclic with perfect tooth shape and lubrication, but over 6% in a two-stage hub.
